recapture xml- cannot set search criteria in 2012 , bug or what ?
COW Forums : Autodesk Smoke
andi no
on May 5, 2011 at 12:29:19 pm
Hi, i tried to recapture xml file using tool/recapture . It will open the recapture window, the prblem is if i change filetype to mov(quicktime) the filename/timecode in search criteria is disabled (grey). This is only for 2012 so i got no problem with 2011. I cannot search the file , in fact i have pointed to the correct root path and when using 2011 , i can find the file easily. Is there any other way i can setup the search criteria in 2012 ??? or did i miss something here ? Did autodesk change the workflow in 2012 ? or some kind fatal bug ?
Thanx
