Conforming alternate framerates... destructive?
COW Forums : Autodesk Smoke
Jim James
on Apr 4, 2011 at 4:04:53 am
How is it possible to conform from one framerate to another? When converting from one FR to another, isn't that someway detrimental to the final project? Isn't there something lost during the conversion?
Joel Osis
Re: Conforming alternate framerates... destructive?
on Apr 4, 2011 at 8:57:56 pm
it depends on how you do it,
anytime you convert framerates it either throws away or makes up info,
if you were to use the framerate converter hidden in the tools menu this would be linear, however if you made a record timeline at your desired framerate with a color, then drop in your footage it will then convert your footage using a timewarp, ultimately giving you more control
make sense?
w: http://www.joelosis.com
e info@joelosis.com
