Animate CC match
COW Forums : Autodesk Smoke
greg gilpatrick
Animate CC match
on Mar 14, 2011 at 5:55:39 pm
Does anybody know if the Match function in the Color Corrector or Color Warper is animatable?
The back in my comp has a lot of lighting changes and I thought that I could resample the match on the Front's CC when the lighting changes but it just compounds it with the previous frame's match.
It seems like the Rematch button would do the trick but it doesn't s work the way I expect. The documentation is pretty sparse on what Rematch does.
Brian Mulligan
Re: Animate CC match
on Mar 14, 2011 at 7:11:20 pm
If you look in the animation channels.. if there isn't a name for match then it's not an annimatable function. I don;t think that it is.
greg gilpatrick
on Mar 15, 2011 at 3:41:59 am
Yeah, I looked in there - didn't see anything.
It works surprisingly well at matching so I'm not really complaining but it would be nice if there was a way to convert the match into CC Basics settings that you could then edit and/or animate.
Thanks for the reply.
Grant Kay
on Mar 15, 2011 at 9:30:51 am
The colour matching in the Colour corrector is not animatable but I believe that the colour matching in the colour warper can be animated over time.
Give it a try and let us know.
Regards
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
