Kona 3 Down Convert on Smoke on MAc
COW Forums : Autodesk Smoke
Lel Haris
on Mar 4, 2011 at 9:05:03 am
I have certified hardware for smoke on mac installed on my system.
I use SD SDI monitor that work fine if work with SD material in SOM.
But if work with HD material i can not preview it in my SD SDI monitor, event thouhg i have down convert it kona 3.
I know this down convert feature works very well in Kona 3 + FCP or event in AJA TV application.
Does smoke support the down convert feature on Kona 3 ??
Need info . I appreciate it. Thank you.
do it digital
