How to set context in smoke
COW Forums : Autodesk Smoke
Diana Yuen
on Feb 25, 2011 at 7:06:46 pm
is there any split bar i can set for reference when i working on colour correction mode? is there something like view context as flame in smoke?
Brian Mulligan
Re: How to set context in smoke
on Feb 25, 2011 at 7:37:04 pm
In Action I think it's just ACTION to see the image in the composite.
On the timeline everything is in context.. but you can try Tryptich view in CC which will give you 2 reference screen in time that you can adjust.
Joel Osis
on Feb 26, 2011 at 5:16:05 am
I\'m pretty sure you can use the compare buffer just like flame and smoke with batch fx,
All you do is press control + g to grab the frame into the compare buffer then press control + b, which will/should bring up the compare buffer line, it probably doesnt work on the timeline but should in all of the other modules
w: http://www.joelosis.com
e info@joelosis.com
