Diffuse Map on 3D FBX.
COW Forums : Autodesk Smoke
Ashish Varghese
on Feb 17, 2011 at 5:15:45 pm
Hi, I am quite new to Smoke...I imported an FBX rounded corner box from the template available in Smoke's Action module and to use it as my screen in my virtual set. So I was trying to use my B-roll (old term) footage as the diffuse map on the 3D cube I brought in. I was not able to. Am I doing something wrong?
Any help would be deeply appreciated.
Thanx in Advance.
Brian Mulligan
Re: Diffuse Map on 3D FBX.
on Feb 17, 2011 at 9:54:00 pm
On the GEOM.. there should be an option to turn off material.. or something like that. Then you should be able to see your diffuse map.
