Gateway invisible?
COW Forums : Autodesk Smoke
Ramil Pasibe
Gateway invisible?
on Feb 16, 2011 at 5:20:38 am
Hi Guys,
I am new to learning SMOKE, my problem is that when I try to import using the network method - then I go on to see the Accessible Servers on Network - I can see that my machine is there and that doing a drop down - I can see that my assigned Framestore is there as well - my problem is that my gateway is invisible - so what I would do is restart the system - then it would be visible again but when I try to say import or link from a specific drive - it says "Connection Reset by Peer" how do I go about this one? Thank you for any insights.
© 2018 All Rights Reserved
