I can't import PRORES422 HQ MOV files to Smoke On MAC..
COW Forums : Autodesk Smoke
Giulio Galinos
on Feb 8, 2011 at 8:37:11 am
Hey guys
I can't import PRORES422 HQ MOV files to Smoke On MAC.. I have done some research and ruled out illegal characters in file names and the fact that WTG is up and running.
Please help
Thanks in advance
Giulio
Rémi Berge
Re: I can't import PRORES422 HQ MOV files to Smoke On MAC..
on Feb 8, 2011 at 11:31:08 am
Hi Gilio,
normally, fcp must be installed on the mac to access the ProRes with smoke.
be careful, however, quicktime and fcp must be left before starting Smoke.
REM
Giulio Galinos
on Feb 8, 2011 at 2:15:51 pm
@ Rémi thx yeah man I have the latest version of FCP Studio installed, as it seems has no effect whether QT or FCP are running in conjunction with Smoke.
Brian Mulligan
on Feb 8, 2011 at 1:01:48 pm
Make sure you are running SP5 or EXT 1 SP3.
There appears to be system specific issues with prores. It works great for some and not for others.
Are you on trial or retail version?
Giulio Galinos
on Feb 8, 2011 at 2:13:00 pm
Hey Brian I'm running the trial version Smoke 2011 SP5....
Jason Kalinoski
on Feb 8, 2011 at 2:31:02 pm
I think it's a limitation of the trial...I could never get Prores to work although different quicktime codecs worked fine.
If I remember correctly, something didn't get installed in the trial version...
Grant Kay
on Feb 8, 2011 at 3:00:40 pm
The gateway which gets installed with Smoke is unlicensed in the trial version. With the commercial version, Smoke and the gateway service are licensed and these formats become available to you.
Regards
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
Brian Mulligan
on Feb 8, 2011 at 4:01:13 pm
Can you use the file I/O to import your QTs? Since that doesn't use gateway.
Giulio Galinos
on Feb 9, 2011 at 9:59:15 am
Hey Brian yeah I tried the I/O option but no glory its really to bad because we were testing Smoke on Mac on a project which absolutely requires a pro res conform from FCP XML.
I can get this right but only with uncompressed 8bit clips, that's no good for our workflow though as the transcodes & file sizes are retarded.
Carl Edwards
on Feb 10, 2011 at 1:23:16 am
There's also a bug in the current version with ProRes import, every time I tried to import prores i got a General Software Error. Autodesk had me set the Wiretap Gateway slaves from 4 to 0 to fix it. They said it should be fixed in 2012. I didn't have this problem in ext.1 but since I moved to ext.1 sp3.
Giulio Galinos
on Feb 10, 2011 at 8:29:58 am
Hey Carl
This is exactly whats happening with on my side been very frustrating trying to figure it out....where do I set the Wiretap Gateway slaves to 0?
Thanks in advance
Giulio
Carl Edwards
on Feb 12, 2011 at 12:07:37 am
Sorry, was off in flameland for a couple of days and couldn't check.
/usr/discreet/wiretapgateway/cfg/wiretapgateway.cfg in case you haven't already found it, and at the end set NumLocalSlaves=0.
Or at least that's what support did for me and told me it was a known bug. YMMV. Good luck.
Hans von Sonntag
on Feb 10, 2011 at 1:49:04 pm
"There's also a bug in the current version with ProRes import, every time I tried to import prores i got a General Software Error. Autodesk had me set the Wiretap Gateway slaves from 4 to 0 to fix it. They said it should be fixed in 2012. I didn't have this problem in ext.1 but since I moved to ext.1 sp3."
Thanks for the head-up. Won't upgrade then.
Hans
Brian Buongiorno
on Mar 30, 2011 at 10:48:32 am
I had this problem just recently after updating my OS to 10.6.6. It was working just fine with 10.6.5. Autodesk has confirmed this so heads up!
Brian
Brian Buongiorno
tonevisuals.com
