Quadro 4000
COW Forums : Autodesk Smoke
Stefan Coory
Quadro 4000
on Jan 14, 2011 at 1:50:53 am
anyone know if then newly released Quadro 4000 is much of an upgrade vs the Quadro fx 4800 as far as Smoke on Mac is concerned ?
Grant Kay
Re: Quadro 4000
on Jan 14, 2011 at 11:27:17 am
Hi
As far as Smoke Mac is concerned the Nvidia Quadro FX4800 is supported but the Quadro 4000 is not supported in the current release.
Regards
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
Stefan Coory
Re: Quadro 4000
on Jan 14, 2011 at 11:37:08 am
Hi grant. Thanks for your reply. So as it's not supported you would see no gains what so ever I assume. Possibly even a drop in performance ?
Stefan
Rémi Berge
Re: Quadro 4000
on Jan 14, 2011 at 3:57:05 pm
Hello,
I tried the trial version quadro 4000 with sp5 on OSX 10.5 and I can confirm that everything works perfectly.
Very responsive, No bug report.
Rémi Berge
Re: Quadro 4000
on Jan 14, 2011 at 3:59:09 pm
Hello,
Stefan Coory
Re: Quadro 4000
on Jan 15, 2011 at 4:50:38 am
Hi remi
Did you upgrde to that card ? If so did you notice much improvement from the card you had previously ?
Cheers
Stefan
Rémi Berge
Re: Quadro 4000
on Jan 15, 2011 at 5:39:00 pm
Hi Stephan,
I tried "Smoke on Mac" very shortly with an ATI 3870, but this card was not recommended and I had a bug, especially in soft Fx.
No, I compared the reactivity with the version of Linux that I use professionally.
Simon Cox
Re: Quadro 4000
on Jan 28, 2011 at 2:04:34 pm
I have just tried the Quadro 4000 out on a new 12 core Mac Pro with OSX 10.6.6 and Smoke 2011 SP5.
But Smoke crashes seconds after startup with not much in the log.
I am curious to know if anyone else is running with SP5 and the 4000 ?
Simon Cox
Rémi Berge
Re: Quadro 4000
on Jan 28, 2011 at 4:04:19 pm
Hello Simon,
the SP5 works fine with the Quadro 4000 on 10.5.5, I believe that all is not validated on 10.5.6.
Simon Cox
Re: Quadro 4000
on Jan 30, 2011 at 3:02:28 pm
@ Rémi,
Thanks, 10.6.5 did the trick. Now it is running very well. Though the real test will be in production next week!
Simon Cox
Rémi Berge
Re: Quadro 4000
on Jan 28, 2011 at 5:39:19 pm
excuse me, it's 10.6.5 and not 10.5.5 .. ;)
Sean Kilbride
Re: Quadro 4000
on Jan 28, 2011 at 9:18:44 pm
Stefan,
If you currently have an NVIDIA Quadro FX 4800 for Mac installed in your system I would say that you will see a minimal gain moving to a Quadro 4000 for Mac. If you are deciding on a new Quadro graphics card for a system that is currently using a consumer graphics solution than I would definitely recommend the Quadro 4000 over the Quadro FX 4800. The Quadro 4000 is cheaper, uses less power, and is based on newer technology.
Sean
Technical Marketing Manager, NVIDIA
Stefan Coory
Re: Quadro 4000
on Jan 28, 2011 at 11:42:25 pm
Ahh thankyou sean , good to know.
So are we likely to see the 6000 anytime soon on the mac ? :-)
