output two different formats at the same time
COW Forums : Autodesk Smoke
Ed Molina
on Jan 12, 2011 at 9:02:21 pm
Heres the question is there anyway to output to two different formats at the same time out of
Smoke (HD and SD). Real time deliverables only gets you one stream either coming from the aja 2k or quadro sdi daughter card for (real time deliverables). Is there a way to get both signals coming simultaneously out of the 5600 card?
Brian Mulligan
Re: output two different formats at the same time
on Jan 12, 2011 at 9:37:10 pm
Not that I know of... RTD would be the way.. but as you can see the OUTPUT only fives you one at a time for playout.
Ed Molina
on Jan 12, 2011 at 10:34:33 pm
yeah , mabey aja will allow dual HD SD realtime conversions in a future version of
aja hardware.
Aaron Neitz
on Jan 14, 2011 at 12:07:47 am
the AJA card (which is basically a Kona 3) can do dual outputs with Final Cut.... which was always useful if you were working in HD and wanted a center-cut output simultaneously.
If we really want a dual output, we loop the HD signal through a deck and have it output a SD downconversion. You get some lag though, which can be distracting.
Ed Molina
on Jan 14, 2011 at 1:58:50 am
I have tried that,but there is a 5 frame delay on SD output of the D5 deck to Digi beta.
