About Ripple Edit
COW Forums : Autodesk Smoke
Diana Yuen
About Ripple Edit
on Jan 4, 2011 at 8:21:44 am
Hi all,
I would like to ask about the ripple edit function in smoke. For example, i have 3 video track , and would like to insert a shot into track 2, However, I would like insert the same duration gap in track 1 and track 3 at the same time (ripple edit all track), Can i do it in smoke ? or i need to move the clips manually? Thanks!
Grant Kay
Re: About Ripple Edit
on Jan 5, 2011 at 10:26:07 am
You do have that function in Smoke..... Ensure that Ripple is turned in the UI controls. Also enable a button labelled SYNC... Should in the same area as the ripple button.
With Sync turned on, if you edit into video layer 2 than video layer 1 & 3 will insert a virtual gap to maintain the edit's sync.
Check out my Flame and Smoke blog at
© 2018 All Rights Reserved
