30" monitor
COW Forums : Autodesk Smoke
Aaron Neitz
30" monitor
on Dec 29, 2010 at 5:34:27 pm
Curious if anyone is using Smoke with a 30" monitor. Does it give you more real estate, or is the entire UI scaled proportionally? And would it work on a Linux Smoke?
Andrew Timms
Re: 30" monitor
on Feb 1, 2011 at 3:33:56 am
We have been using one on Smoke for Mac - the UI is scaled as if it were 1920 * 1200 for the most part. However the edit desk is slightly larger and so are the overlayed UIs.
Andrew Timms
http://www.flyingfish.co.nz
