EDL Manager Problems
COW Forums : Autodesk Smoke
greg gilpatrick
on Oct 31, 2010 at 8:54:55 pm
Hello,
I am getting some weird errors when trying to do a simple conform using an EDL and Quicktime clips. All of a sudden, the EDL Manager refuses to see any of my reels. It just says "Library Reel: untitled" and if I click the pop-up beside it, it only has two choices of "..." This happens in the Load EDL window and in the EDL Manager.
If I try to type in the name of the reel that has my media, it creates a new reel, with only an unlinked assemble in it.
I also sometimes get an error that says "Illegal FCM" in the EDL Manager. This is a good EDL which I conformed with the same machine 2 days ago.
We've already tried re-installing Smoke, trying a new project, library, and even a different disk for the framestore.
This is a new 12-core Mac Pro, which I know is not supported at the moment. But it was working fine a couple days ago. Anybody have any suggestions?
Matt Riley
Re: EDL Manager Problems
on Nov 1, 2010 at 2:25:42 am
Can you try conforming from an XML instead?
-Matt
Grant Kay
on Nov 1, 2010 at 11:38:16 am
Hi Greg,
Could you log it with Autodesk support so that they can examine the EDL?
Many thanks!
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
greg gilpatrick
on Nov 2, 2010 at 2:09:18 pm
Will do, Grant. Thanks
