Soft and hard import?
COW Forums : Autodesk Smoke
Rick Turners
on Aug 31, 2010 at 12:30:36 am
Can someone explain the difference?
I'm trying to import a clip, I have the "soft import full res" box checked, as I'd prefere to not create a duplicate. (which, from my understanding, is what hard import does)
I have that box checked, but Smoke is still taking a few minutes to import a single clip, says its creating proxies.
Is there a way to import something directly without loading it, a la how FCP works?
Just taking Smoke for a spin!
Grant Kay
Re: Soft and hard import?
on Aug 31, 2010 at 9:25:33 am
When you created your project there was an option to create proxies. Go to the preferences menu and go into the project settings and turn proxies off and modify the project.
When you import again than the software will not generate proxies and the import will be instant.
Regards
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
Rick Turners
on Aug 31, 2010 at 8:51:10 pm
Thanks Grant, figured it was a simple setting somewhere.
While on the topic of just getting started with Smoke, I've tried to install the exercise files and have been getting this error when I run the smoke_essentials_setup file
Autodesk Media and Enterainment
User and Project Creation for Smoke 2011 Mac
Setting up Installation
Please enter Admin Password
Password:
This section is where you define the storage device
The storage device or StoneFS Partition is where all of your image clips are stored on
Please select a storage number (ex. 1 - 7). If not certain, type number 1 and hit enter.
Partition Stone and Wire Setup Incorrect
Please check stone+wire.cfg
logout
[Process completed]
Any thoughts appreciated.
Grant Kay
on Sep 1, 2010 at 9:16:35 pm
From the message it looks like your Stone+Wire configuration is not setup correctly. Therefore the installer cannot install the media files in the right place.
Are you able to boot into smoke? Load media, create something?
This could have been incorrectly set during the install.
I suggest posting this on the Autodesk Area forums so more Autodesk people might be able to help you out with this.
Regards
Grant
