AAF workflow
COW Forums : Autodesk Smoke
Pete Fausone
AAF workflow
on Aug 30, 2010 at 5:41:12 pm
Does anyone have any real world experience with finishing in Mac Smoke starting with an Avid AAF?
What comes across from Media Composer 5 for example? Does it even work? Is it something to consider as a way to online
from an Avid offline?
Brian Mulligan
Re: AAF workflow
on Aug 30, 2010 at 5:45:48 pm
AAF import does work on Smoke. Not sure if MC5 has changed anything in the translation. I don't deal with Avid.
Paul Carlin
Re: AAF workflow
on Sep 8, 2010 at 4:11:56 am
My limited experience is all negative. I would not rely on the AAF working. Most of the problems were caused by assistant editors not following correct procedures, but by then it's too late to fix.
ALWAYS output EDLs for each layer in addition to the AAF.
http://www.sparkwizdom.com/2010/02/how-to-output-edl-from-avid-media.html
