SAN disappears after install Smoke 2011 on mac
COW Forums : Autodesk Smoke
Leo Lin
on Aug 18, 2010 at 5:34:10 pm
Hi there,
Before install smoke 2011 on mac, everything works just fine, after install, SAN storage disapears everytime system restart. I have to run xsand manually to mount the SAN volume. Uninstall smoke, SAN comes back.
Mac Pro/10.6.3/Xsan 2.2/Smoke on mac 2011 SP3.
Thank in advance.
Leo
Joel Osis
Re: SAN disappears after install Smoke 2011 on mac
on Aug 19, 2010 at 12:56:27 pm
It might be a 64 bit issue, by default after installing Smoke it will reboot in the 64 bit kernel. Make sure your SAN has the appropriate drivers
w: http://www.joelosis.com
e info@joelosis.com
Leo Lin
on Aug 19, 2010 at 5:53:44 pm
Smoke2011 requests kernel in 32 bit, not 64 bit, according to Smoke installation guide. And Xsan client works fine until we install Smoke.
Andrew Timms
on Sep 14, 2010 at 1:02:50 am
Hi
I had this problem when we got Smoke also.
Eventually I removed XSAN.
If you have the Stone set to your Xsan volume then Smoke creates the dir before Xsan does. This means Xsan cannot mount the volume. It also creates a heap of problems with Xsan internal processes.
Cheers
Andrew Timms
http://www.flyingfish.co.nz
