@ James Mirrors - Character Post below this one.
COW Forums : Autodesk Smoke
Brian Mulligan
on Aug 17, 2010 at 7:43:08 pm
For some reason I can't reply to your original post, so hopefully you will see this. :)
Are using trying to use the UP-ASCII special Chars? You can't type them with the keyboard, but you should be able to use the UI keyboard and type your special characters.
Alan Maiden
Re: @ James Mirrors - Character Post below this one.
on Aug 19, 2010 at 2:23:31 pm
I am getting this text problem and it is not due to not using UI keyboard. The UI keyboard works fine on the Smoke on Linux but the same font in the same folder but accessed from a Smoke on Mac does not work. The font works fine if you are in the text module but in 3D text you just get UNSUPPORTED CHARACTER message. I wonder if it is a Linux versus Mac translation of the fonts.
Grant Kay
on Aug 20, 2010 at 7:48:28 am
Hi
What is the format of the font? TrueType? Mac TrueType or Windows TrueType?
You could bring it into a font programme and re-export it as a Windows TrueType... that might do the trick!
Good Luck!
Regards
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
