Smoke hotkeys to mimic Flame/Inferno
COW Forums : Autodesk Smoke
Stefan Coory
on Aug 13, 2010 at 4:14:50 am
Hi folks
anyone seen a user or hotkey setup for smoke that makes it act like flame. I know I could go through all the modules and try set it up but keep running into global vs local conflicts etc.
Cheers
Grant Kay
Re: Smoke hotkeys to mimic Flame/Inferno
on Aug 13, 2010 at 9:58:37 am
Currently there are no pre-made setups to make smoke mimic Inferno/Flame hot keys.
If you want this than you will have to map the keys yourself.
Regards
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
Stefan Coory
on Aug 13, 2010 at 10:05:16 am
bugger
thought that might be the case , thanks for the reply Grant!
Anyone else out there been through the pain already ?
Jean-Marc Laurin
on Sep 9, 2010 at 1:38:13 am
I went through the process of remapping at least 2thirds of the hotkeys so i wouldn't get lost switching from Smoke to Flame to Avid to Nuke and FinalCut. It's been a few years in the process. When batch came for smoke, i tweaked everything so that it would behave a little like flame and nuke.
I have several backups. )))
Frederic Warren
on Sep 10, 2010 at 1:20:38 pm
We just announced the 2011 Extension release @ IBC and you will be glad to know that it is now possible to use the Flame hotkey preset in Smoke. You simply need to select it as your Preset when crating your user.
The opposite is also true. You can now drive Flame using the Smoke hotkeys
fred
fred
Jean-Marc Laurin
on Sep 10, 2010 at 11:07:25 pm
Cool ! Salut Fred, ├ža fait un bail !
JM
Frederic Warren
on Sep 14, 2010 at 1:29:29 pm
Salut Jean-Luc!
En effet!
I hope everything is going on your side!
fred
