Smoke & Kona LHi vs. 3
COW Forums : Autodesk Smoke
Jon Merrifield
on Jul 29, 2010 at 7:25:44 pm
Is this possible? I read some posts from January 2010 discussing this very matter but there was no conclusion. I have a system with a Kona LHi and Break Out Box. I only need monitoring at this time. No ingest from tape is needed currently. Will the Smoke on a Mac work, as far a external SDI monitoring utilizing the Kona LHi instead of the recommended Kona3? If not, why not? this is the real question.
Thanks for you input.
Grant Kay
Re: Smoke & Kona LHi vs. 3
on Jul 30, 2010 at 9:47:09 am
Smoke only runs with the Kona 3 card. As far as I was told by AJA, the Kona 3 card still offers the required functionality by Smoke which is not supported by the LHi.
The Kona 3 is the only supported card for Smoke. Any other AJA cards will simply be ignored by the software.
Regards
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
Bjarki Gudjonsson
on Jun 23, 2011 at 11:44:20 pm
Bummer.
