59.94p problems...
COW Forums : Autodesk Smoke
Ed Poulson
59.94p problems...
on Jul 27, 2010 at 2:53:21 pm
I have been supplied an uncompressed quicktime at 1920 x 1080 59.94p. I have imported this file into smoke and tried to lay the qt out by my smoke will not genlock as the only reference i have is 1080 59.94i not 1080 59.94p, 1080 59.94p i have been told does not exist so how have i been supplied this format in the first place?
Please help!
Brian Mulligan
Re: 59.94p problems...
on Jul 27, 2010 at 5:51:24 pm
As far as I can tell any QT imported will be flagged as Progressive.
When in fact it may be interlaced. If you believe the source to be interlaced then you can change the field dominance to F1.
If it is progressive, just change it anyway and see what happens.
© 2018 All Rights Reserved
