Shift+F in Smoke to drag/copy - what's FCP hotkey equivalent?
COW Forums : Autodesk Smoke
Aaron Neitz
on May 27, 2010 at 2:52:12 pm
On the editdesk to drag a copy form your in/out with the Smoke Hotkeys is Shift+F. According to the Hoykey reference guide, Shift+C is the equivalent in the FCP hotkeys. But it doesn't work.
Anyone figure it out?
I searched in the Hotkey manager and couldn't find the command to boot.
Erwan Le Cloirec
Re: Shift+F in Smoke to drag/copy - what's FCP hotkey equivalent?
on May 28, 2010 at 1:33:37 pm
Just press C when you have a In/Out points in your clip, it will copy the In/out segment.
Alt+X to remove In/Out inside the clip.
Hope it will help you.
Erwan
Aaron Neitz
on May 29, 2010 at 6:38:56 pm
Sorry Erwan, C copies the clip in it's entirety. If you in/out selected it will keep those marks in the copied clip.
I'm looking for the equivalent to Shift+F (the Smoke hotkey for 'Drag Copy Clip (In to Out)'
Scott Davis
on May 31, 2010 at 1:55:49 pm
Aaron, I think what you are asking for is called a subclip in FCP which is command-U.
Scott Davis
View Scott Davis's profile on LinkedIn
Aaron Neitz
on May 31, 2010 at 7:59:06 pm
I'm asking about how to do it in Smoke.
