Stone + Wire problems on a Mac
COW Forums : Autodesk Smoke
Bjarki Gudjonsson
on Jan 24, 2010 at 9:33:48 pm
Hi guys.
I finally got around to installing the Smoke for Mac trial, but haven't been able to boot it up because of Stone + Wire problems. When I try to restart the service, it goes green for a little while but turns red again. I've searched online and seen others have this trouble, but no solutions.
Any experience with this or ideas?
Bjarki
nick hasson
Re: Stone + Wire problems on a Mac
on Jan 25, 2010 at 2:24:17 am
whats the software say when you try to run it? Can you give more details? any error messages?
Nick Hasson
http://www.niceedits.com
Bjarki Gudjonsson
on Jan 26, 2010 at 12:28:49 pm
Hi Nick and thanks for the reply.
Smoke stops on startup with the following message:
Error: VOLUMEMGT: Failed to initialize Stone+Wire connection.
The log reads the following (and it is an exciting read):
1/25/10 1:50:54 PM [0x0-0x414414].com.apple.FinalCutPro[8361] *** error: can't allocate region
1/25/10 1:50:54 PM [0x0-0x414414].com.apple.FinalCutPro[8361] *** set a breakpoint in malloc_error_break to debug
1/25/10 1:50:54 PM [0x0-0x414414].com.apple.FinalCutPro[8361] Final Cut Pro(8361,0xa0a22500) malloc: *** mmap(size=268439552) failed (error code=12)
1/25/10 1:50:55 PM [0x0-0x414414].com.apple.FinalCutPro[8361] Final Cut Pro(8361,0xa0a22500) malloc: *** mmap(size=268439552) failed (error code=12)
1/25/10 1:50:55 PM [0x0-0x414414].com.apple.FinalCutPro[8361] *** error: can't allocate region
1/25/10 1:50:55 PM [0x0-0x414414].com.apple.FinalCutPro[8361] *** set a breakpoint in malloc_error_break to debug
1/25/10 1:50:56 PM [0x0-0x414414].com.apple.FinalCutPro[8361] Final Cut Pro(8361,0xa0a22500) malloc: *** mmap(size=268439552) failed (error code=12)
1/25/10 1:50:56 PM [0x0-0x414414].com.apple.FinalCutPro[8361] *** error: can't allocate region
1/25/10 1:50:56 PM [0x0-0x414414].com.apple.FinalCutPro[8361] *** set a breakpoint in malloc_error_break to debug
1/25/10 1:50:57 PM [0x0-0x414414].com.apple.FinalCutPro[8361] Final Cut Pro(8361,0xa0a22500) malloc: *** mmap(size=268439552) failed (error code=12)
1/25/10 1:50:57 PM [0x0-0x414414].com.apple.FinalCutPro[8361] *** error: can't allocate region
1/25/10 1:50:57 PM [0x0-0x414414].com.apple.FinalCutPro[8361] *** set a breakpoint in malloc_error_break to debug
Bjarki Gudjonsson
on Jan 28, 2010 at 8:58:57 pm
Alright, so the last post was a little detailed, but any suggestions would be welcome!
Brian Buongiorno
on Mar 20, 2010 at 2:07:36 pm
Hi Bjarki,
I'm seeing this message too. Did you get it resolved?
Brian
Bjarki Gudjonsson
on Mar 20, 2010 at 11:46:31 pm
Nope. The time I had hoped to use to check Smoke out has passed for now, so I haven't had time to worry about it. But if you get the chance to try it out, let me know!
B.
Brian Buongiorno
on Mar 22, 2010 at 12:54:20 am
Hi Bjarki,
I found that it was related to my Mac hostname not having the proper DNS server. I was using a slow airport connection at home. Once I hooked up the ethernet cable, and reestablished the proper DNS server, the problem was resolved. Smoke starts up properly now. Interesting. I did find a bit of mention in the current Smoke on Mac "known issues and bugs" document. It's under sys00321783 - network issue
Email me directly for the issue on your expired license if you want.
Regards,
Brian
brian@brian-buongiorno.com
http://www.brian-buongiorno.com
david stacy
on Dec 26, 2010 at 11:47:11 pm
Due to a bug in Smoke you need to be connected to the Internet to start Smoke. Also, you need to be connected with a static IP address. Some Internet providers, like TimeWarner, use a dynamic IP address which changes every 7 to 10 hours for their residential service; only their commercial service has a static IP address.
Also check that your modem/route are set to a stable IP address. Tech support will help with this.
I was able to start Smoke until I changed my Internet provider. No I am not able to start the program. To test my theory take your computer to somewhere with a different provider, maybe the Apple Store, plug in and see if it starts.
Good Luck,
David
