Light Wrap
COW Forums : Autodesk Smoke
Adam Gagnon
Light Wrap
on Jan 21, 2010 at 3:41:22 pm
I thought I would give the Smoke trail a go and so far so good; but I'm looking for a little help in creating a light wrap for my key.
Any help, would be greatly appreciated.
adam
nick hasson
Re: Light Wrap
on Jan 21, 2010 at 8:43:09 pm
this is a tricky one. I usually would use a spark for that, but we do not have sparks yet for the mac version.
Nick Hasson
http://www.niceedits.com
Joel Osis
Re: Light Wrap
on Jan 21, 2010 at 10:14:08 pm
Hey Adam,
Its not too hard without sparks ...however it is kind of linear in its workflow,
the way i do it is
1. put the alpha on the timeline
2. ivert the color with a soft cc
3. add an axis soft effect to the same clip and blur it out
4. then find the "FX" tab and use logic ops and multiply you new clip with your original alpha
5. All thats left to do now is use your bg as the front and your new lightwrap clip as the matte and blend this on top of your original clip.
hope that helps
Joel
Adam Gagnon
Re: Light Wrap
on Jan 21, 2010 at 11:53:06 pm
Thanks, I'll give it a try.
Barry Goch
Re: Light Wrap
on Jan 23, 2010 at 9:47:42 am
You can also do this in the modular keyer by doing the blur trick on the back ground, but use an edge node combined with the matte, then use a logic op to just wrap the image then blend that back on the top. Give that a try.
Barry
Joel Osis
Re: Light Wrap
on Jan 30, 2010 at 11:04:32 am
Forgot about the addition of the modular keyer to smoke 2010,
I use smoke advanced with batch at my work, prior to that I was on an old SGI IRIX box running 2007 that
only had DVE, so my thinking prior to having batch was very linear
