Smoke not relinking to FCP XML
COW Forums : Autodesk Smoke
Robert Brown
on Dec 28, 2009 at 8:29:33 am
I've been testing out smoke for Mac on an all supported Mac/Kona system and build a timeline in FCP - simple cuts only but 2 layers - export an XML and them import all into Smoke. It has no problem with the XML, finds all of the media and even says media is re-linkable in the import module and when I click on relink it says "nothing done 40 files missing" even though all the files are listed right there. Am I missing something? This is a 720 60 project all media captured U/C 8 bit with the Kona. Any ideas?
Erwan Le Cloirec
Re: Smoke not relinking to FCP XML
on Jan 8, 2010 at 4:54:05 pm
Hi Robert,
In the import tab, you have to check in the clip metadata option"Tape From Edit list" and "Timecode from editlist" select also Quicktime on file type. Then import All Files... if you go after to the relink tab it should work.Just Press Relink.
© 2018 All Rights Reserved
