Dead Pixel Fix
COW Forums : Autodesk Smoke
Kelly Golby
Dead Pixel Fix
on Mar 2, 2009 at 7:18:15 pm
Is there a quick way to fix dead pixels? I've used the clone tool but I have over 30 minutes of footage and going frame by frame is a long process. Is there a shortcut? The footage was shot on Red and I'm using Smoke 2009 SP2.
KG
moody glasgow
Re: Dead Pixel Fix
on Mar 2, 2009 at 7:46:13 pm
I'm not too familiar with working with red, but it sounds like you have a bad pixel that stays bad through out the shot. I would try auto-paint. It should do the trick.
moody glasgow
smoke/flame
nick hasson
Re: Dead Pixel Fix
on Jun 10, 2009 at 5:54:04 pm
One thing I have done in the past is to slide the pixel next to it over. This will fix it in 98 percent of the footage. Then I paint the rest.
Nick Hasson
Editor/coloirist
http://www.niceedits.com
Smoke/FCP/Apple Color.
Steve oakley
Re: Dead Pixel Fix
on Jun 17, 2009 at 4:28:20 am
BCC Sparks has a pixel fixer operator for just this problem. click the cross hairs on the bad spot and its gone. it has 10 pixel fillers in a single operation. this is in the desktop AE / FCP / PP / avid versions, not sure if it filtered over to sparks yet.
