is it posssible to play out a HD 25psf project to PAL 24in25 tape
COW Forums : Autodesk Smoke
Justin
on Apr 14, 2007 at 6:49:52 am
Hope the topic makes a bit of sense....
Does anyone know if the following is possible?
I have onlined at HD 25psf but need to provide sound with a '24 in 25' digibeta.
Normally what has happened is that I would playout to 25psf HD. Digitise that into AVID as a SD film project and then playout so that 2 additional fields are created per second.
a diagram of what happens can be seen here http://24p.com/PAL.htm
Is this possible via smoke?
Thx.
