Importing Quicktimes
COW Forums : Autodesk Smoke
renderboy
on Jan 16, 2007 at 3:55:02 pm
I am trying to import quicktime movies created in Motion 2 into Smoke vers 7. Nothing works. Is it a Motion 2 issue? A Smoke issue? Anyone have any similar problems?
I have very simple graphics created in Motion 2. I export the sequence as a lossless+alpha quicktime in the Motion presets. the Smoke won't import it. I have tried numerous other quicktime codecs. No joy.
Can you help?
BKM
Re: Importing Quicktimes
by
on Jan 17, 2007 at 2:04:20 pm
Just curious.. are you on a Linux box? If so there is currently no QT codecs for Linux. You must import as a file sequence.
If you are on IRIX. Then QT animation is your best bet.
BKM
renderboy
on Jan 17, 2007 at 5:58:18 pm
Nope. Not on LINUX. Still trying different QT types with no luck. Wierd.
BKM
by
on Jan 17, 2007 at 8:26:36 pm
There isn't audio on these Qts is there? Audio is a showstopper.
Also, what version of Smoke are you using? Some versions don't play well with QT 7.
BKM
moodyglasgow
on Jan 18, 2007 at 8:12:44 am
A little bird told me to that Quicktime is coming to Linux...
moody glasgow
smoke artist / editor
jimmybee500
on Jan 18, 2007 at 10:15:20 am
Thank god for that. That is good news.
*Production Studio Premium / *Combustion 3
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
renderboy
on Jan 18, 2007 at 11:01:32 am
Thanks for the reply.
I'm exporting using Quicktime Version 7.0.4 and the Smoke is Version 7.0.13. Not exporting audio.
moodyglasgow
on Jan 18, 2007 at 3:52:21 pm
As of now, you are not able to import a quicktime file into the Smoke. Your best bet is to convert it to a targa sequence.
moody glasgow
moodyglasgow
on Jan 19, 2007 at 8:36:31 pm
my bad, didnt realize you were working on Unix.
moody glasgow
BKM
by
on Jan 18, 2007 at 5:17:49 pm
Can you import any other Qts form another source? AE maybe? I would almost think that it is a motion issue if that is the only QTs giving you trouble.
And again.. I would use Animation codec as it seems to behave the best.
BKM
jimmybee500
on Apr 4, 2007 at 12:54:19 pm
Looks like Autodesk have fixed this on Linux!
