Import .mov file
COW Forums : Autodesk Smoke
David Albin
Import .mov file
on Dec 8, 2006 at 5:53:59 pm
Trying to import a mov background without much success.
Any specifics that I need to know regarding compression, size, etc.?
Dave
J
Re: Import .mov file
by
on Dec 8, 2006 at 8:53:38 pm
As far as I know you can't play .mov files on Linux, try a targa or tiff sequence
David Albin
on Dec 11, 2006 at 5:56:44 am
I should have mentioned that I'm on a SGI Tezro system.
I have been able to import a clip that was compressed with an apple jpeg.
A producer I work with purchased a clip from a stock footage place.
alan ellis
on Dec 11, 2006 at 6:38:19 pm
we usually use quicktime animation codec. Never had any problems.
hope this helps
BKM
by
on Dec 11, 2006 at 8:39:55 pm
With some stock footage clips the alpha clips are not in RGB mode, the are in Grey. So you need to convert them as SGI/Smoke only deals with RGB video.
BKM
