16:9 project !!!
COW Forums : Autodesk Smoke
rohan khokar
16:9 project !!!
on Oct 20, 2006 at 6:17:58 am
hi...im working on smoke6.7...working on 25fps and the resolution of my project is 720x576...my client has shot on HDV in 16:9 mode....now what settings do i need to do in my project so that my footage gets captured in 16:9....coz right now when i try to capture my rushes, i see it as a full-frame (no letterbox or 16:9)..plz help !!!
BKM
Re: 16:9 project !!!
by
on Oct 20, 2006 at 2:43:12 pm
if you capture your material via tape, then just set your aspect ratio from 4x3 to 16x9. It's in the input clip menus. Then your video will show 16x9 on the desktop. I assume that your recorded HDV clips is just anamorphic? Or what resolution did they shoot in?
BKM
Eric Susch
on Oct 23, 2006 at 10:32:52 pm
I believe all flavors of HDV have square pixels, but I could be wrong. You really need to know which camera the footage was shot with because every manufacturer has slightly different specs.
