Output to HD
COW Forums : Autodesk Smoke
jhmcf2
Output to HD
on Oct 11, 2006 at 1:06:46 am
I have both FCP and a Discreet Smoke to output to HD. When I output from the Smoke I am getting a Purple Signal. I don't think it is the HD Deck because I can output from FCP without a problem. Any ideas on what may be causing this purple signal?
Del Holford
Re: Output to HD
on Oct 11, 2006 at 2:51:29 pm
Are you using the same connections or different? Are you using the same reference to smoke as to the HD Deck? Give us a few more details and we could help more.
Del
fire*, smoke*, photoshopCS2
Charlotte Public Television
jhmcf2
Re: Output to HD
on Oct 11, 2006 at 4:42:41 pm
The reference and connections are all the same. I checked all the internal settings on the HD Deck and they appear to be accurate. I was thinking that there may be a Video Preference in the Software that I may be missing.
Chris Hanson
Re: Output to HD
on Oct 12, 2006 at 1:03:00 pm
Are you feeding the smoke with proper tri-level sync ? The Linux smoke's need proper TLS even when running at 25fps. Dont know if this would cause the purple colouration though.
cheers
chris
BKM
Re: Output to HD
by
on Oct 13, 2006 at 1:53:42 am
I have had this on SD as well. On my Octane 2 I would get this pink digital hue on output when the VBOB was acting up due to some reason. Regualr monitoring would be fine. Ususally a reboot of the VBOB and SGI would fix it.
Not sure if Linux acts the same way... or if this even helps.
Brian
steve997
Re: Output to HD
on Oct 14, 2006 at 5:25:58 am
One possibility perhaps:
On the smoke, you have options to output in 4:4:4 and 4:2:2.
In the output menu, go to the engineering sub-menu and check that it is set for 4:2:2 and YUV-RGB conversion.
Although it's not the same, I have seen purple looking video on input clip when trying to capture material on the HDCam SR which is 4:4:4 recorded and your settings are 4:2:2.
Regards,
Steve
jhmcf2
Re: Output to HD
on Oct 15, 2006 at 11:36:50 pm
Thanks all,
I changed the output settings and that seemed to fix the problem.
