Smoke OMF to Pro Tools
COW Forums : Autodesk Smoke
Morrandez
on Aug 16, 2006 at 4:55:38 pm
I am exporting an OMF from Smoke and Pro Tools can't read it. Any suggestions? Bit rate?
thanks
Del Holford
Re: Smoke OMF to Pro Tools
on Aug 17, 2006 at 4:20:41 pm
You've come across my favorite smoke topic. You need to go to the smoke forum at Discreet's website. The archive there discusses what you are experiencing.
The Cliff's notes version: ProTools past v6.5 won't read a smoke version 6 or 7 omf. There are translators in the Mac world that will convert the omf files so that ProTools will read them. One of those is on DigiDesign's website.
Another thing that helps is to save the omf to your local system drive and then transfer those files to an accessible file from ProTools. Even with all this, sometimes it still won't work. Be sure your label naming protocols are standard as well. Good luck
Del
fire*, smoke*, photoshopCS2
Charlotte Public Television
stephane labrie
on Aug 18, 2006 at 12:29:29 am
Hi!
Which version of ProTool was used? I've heard that PT 7.1 has some OMF/AAF bug fixes that would allow you to import smoke OMF files.
