Can Smoke Read EDLS from Premier 6.5????
COW Forums : Autodesk Smoke
IceMan23b
on Aug 31, 2005 at 3:04:43 pm
I have a project where I'm going to do the offline in premier 6.5. I wanto to know if I export the EDLS from premier, will Smoke read them, so the online will be faster in the smoke.
Del Holford
Re: Can Smoke Read EDLS from Premier 6.5????
on Aug 31, 2005 at 8:00:35 pm
All you need is a CMX 3600 formatted EDL (GVG or Sony will also work) and smoke will read it fine. It won't track dve or time warp moves but does note them. It works best if you create a separate EDL for each video layer you create. Also keep production notes and save a quicktime movie from offline for reference.
Be careful with reel numbers. Number tapes without extraneous info really helps to keep a clean EDL. I instruct my producers to go from 1 to nn and it saves headaches in EDL import.
Del
IceMan23b
on Sep 1, 2005 at 3:12:53 pm
Thanks for the info. I will make them the way you told me. Thanks againg.
Sameer Shrivastava
on Oct 31, 2005 at 7:50:59 pm
Keep a cut only ver of the edl ready. I had seen problems with shots having dissolves with them.
sameer shrivastava
