LED Wall Processor
COW Forums : Live & Stage Events
Jason Horn
LED Wall Processor
on Oct 6, 2017 at 2:37:09 am
Good evening,
I have an LED wall that has a resolution of 3072X1408. It is currently being fed by 2 NovaPro wall processors from a Christie Spyder. It is using the DVI inputs on each, over 10BaseT for transport at 1536x1408 per side. Since this processor also has 3G SDI inputs, I wanted to run the copper to each, and eliminate the DVI extenders. However, I can't get a signal to them. Will 3G recognize a format with over 1080 vertical lines? I understand that there are specific formats related to 3G SDI, but the data being passed seems well within the limits. Any ideas?
Vince Becquiot
Re: LED Wall Processor
on Oct 6, 2017 at 3:50:27 am
Hi Jason,
SDI processing will almost certainly need a SMPTE standard signal and it's very limited.
That usually means 720 30/60P or 1080i / 1080P 30/60P only.
After that we get into the 6G/12G for 2k/4k standards.
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
Jason Horn
on Oct 6, 2017 at 4:03:58 am
Thanks Vince.
What about running the 2 outputs at 1080p, and then scaling them with the NovaPros to the 1536x1408? Although I am sure the scaling power of the Spyder is much better than these units.
Jason Horn
on Oct 6, 2017 at 4:05:33 am
Content is currently created at 3072x1408, and then compressed to 1080 for transport in our system.
charles tim
on Mar 1, 2018 at 10:15:02 am
you can get the latest led video wall with Novastar Pro processor from here: novaledscreens
