5kx1k video format on playback pro?
COW Forums : Live & Stage Events
Frank Collins
on Jan 14, 2016 at 4:03:45 pm
Hi, looking for suggestions on file format/settings with this...
I'm creating a 5000x1000 1 1/2 minute video that will be sent through Playback Pro for projection onto 2 100'x20' screens. h264 won't allow for 5000 pixels wide. I was told to keep it under a gig in total size...
thoughts?
-thanks, frank
Vince Becquiot
Re: 5kx1k video format on playback pro?
on Jan 14, 2016 at 10:40:09 pm
Hi Frank,
ProRes is actually a preferred format for PBP, I usually stay away from H.264 whenever possible.
Just make sure the machine can handle the processing, and that the drives can handle the data rate, most likely a RAID 0/5.
As for the person telling you to keep the file under a certain size, they have likely never dealt with 5K.
With ProRes, you might be looking at 10 Gigs+ depending on the frame rate.
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
