Screen Pro 2 hd input on vga 1080p
COW Forums : Live & Stage Events
Eric Rothchild
on Aug 5, 2014 at 8:10:12 pm
Im trying to take 1080p over vga into a screen pro 2 hd, the video card on the computer im using does 1080p no problem but for some reason the screen pro wont see it as a valid signal. does any one have any trick or know of a reason why i am having issues with this.
part 2
i did take the out put from the computer and go direct into my preview monitor. then in catalyst control i turned off edid then re connected output of pc to screen pro. restarted computer and forced acquired input the signal came through but read as dual link and the image looked horrible.
any thoughts
Thomas Leong
Re: Screen Pro 2 hd input on vga 1080p
on Aug 6, 2014 at 12:42:04 pm
Part 1
If your problems are similar to this thread -
http://forums.creativecow.net/readpost/158/857738
suggest you try his solution as posted in the ControlBooth forums as indicated.
Part 2
Not being familiar with Screen Pro at all, I have no answer.
Thomas Leong
