PC Laptops, Monitor out rez tops out at 1024 x 768
COW Forums : Live & Stage Events
Eric Lagerlof
on Sep 23, 2013 at 9:15:47 pm
I'm at a show running laptops into a Screen Pro 2. I've just run into 2 recently built laptops that can run their displays at 1600x900 or more but when I go into the graphics properties with multiple displays, the 'Monitor Out' resolutions top out at 1024. This includes one with an extra nVidia card, not just the intel 4000 chip. Am I missing something here? (I'm trying to send out 1280x720-16x9), and would settle for 1366x768) But even if I drop the laptop display rez to something lower the monitor output still stops at 1024.
Seth Tours
Re: PC Laptops, Monitor out rez tops out at 1024 x 768
on Sep 24, 2013 at 1:26:28 am
You need a vga edid manager. Something like this http://www.connectpro.com/prod_vid_ddcVGA.html
Cheers,
Seth
Eric Lagerlof
on Sep 24, 2013 at 3:11:54 am
Seth, thanks for the info. I always assumed edit was only passed via digital connections (DVI, HDMI) and not good old analog via. I guess the newer vga connectors try and collect edid info?! The
Screen Pro 2's edid manager was set to 1280x720 but I doubt its vga connectors were designed to send out that digital info.
Walter Soyka
on Sep 24, 2013 at 3:34:34 am
[Eric Lagerlof] "Seth, thanks for the info. I always assumed edit was only passed via digital connections (DVI, HDMI) and not good old analog via. I guess the newer vga connectors try and collect edid info?!"
EDID is a part of VGA's DDC, or Display Data Channel [link].
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Eric Lagerlof
on Sep 24, 2013 at 5:52:09 pm
That answers one question. Though in this situation the ScreenPro 2's EDID manager was set to 1280x720...
On another note, know some good tricks to get a Macbook Pro to send out 1280x720 via its VGA/DisplayPort output? 1280x768 seems to be all that's on offer. And while the SP2 sees it(1280x768), it doesn't seem to be able to resize it anywhere close to fitting a 16x9 screen in either 1:1 sampling mode or 'Oversampling' Mode. I own a MBPro, non-retina, and I still hate to seem them at shows with Barco or Analog Way switchers...aaarrgh!
