Panasonic HMX100 switcher multiview cropped in 1080/59i mode
COW Forums : Live & Stage Events
Curtis Rempel
on Sep 18, 2013 at 5:54:54 pm
Working with a Panasonic HMX100 switcher in 1080/59i, the multiview monitor, a Dell U2711, displays a slightly cropped image around all edges, leaving the text labels cut off. however, setting the video format of the switcher to 720/59p does not crop. I set the U2711 to 1:1 to see the 1920x1080 image actual size (the monitor will do up to 2560x1440) and the actual size is also cut off as well so it's definitely not a monitor auto adjustment issue - it seems like it's coming in that way from the switcher. Trying another Dell monitor, different model, results in the same thing.
Here is the left edge of the screen with the switcher at 1080/59i showing the text cut off:
and also at 720/59p showing the text in full:
Any ideas how I can avoid this cropping at 1080/59i ? It sure is annoying....
