LG W2243T out of range with A/V Switcher
COW Forums : Live & Stage Events
Duane Cabot
on Jun 8, 2013 at 3:42:22 pm
Hi, I have a LG Flatron W2243T monitor that I want to use as a multiview display with my a/v switcher (sony MCS-8M). When I plug it via a DVI cable I get a ''out of range 33.6 / 30 hz'' message. I can't change settings on the DVI out put of my switcher...what can I do?
Phil Senger
Re: LG W2243T out of range with A/V Switcher
on Jun 20, 2013 at 9:20:47 pm
I don't have a definitive answer, only a suggestion.
Try using a DVI -> HDMI cable, DVI out of the switcher, HDMI into the monitor
Phil Senger
SW Audio+Visual
Vancouver, BC
http://www.sw-online.com
nick ring
on Nov 5, 2013 at 5:45:58 pm
Replying for a bit of future reference.
I just encountered the same problem with an LG 2242T and an Acer monitor as well (which gave me less info). I did find out that if I set the MCS-8M to 720 instead of 1080, then the monitors will recognize it. Obviously not ideal. In any event, I've only been playing with it for an hour, so when I find out more, I will post it here.
Next, on to getting my MBP and the DVI in to work.
