Creating/sending custom lower thirds during live stream event
COW Forums : Live & Stage Events
James Sapione
on Apr 16, 2013 at 4:16:30 am
What program to create lower thirds for live streaming multicam event?
Hello
I'm directing multi camera live streaming events. I want to add lowerthirds(15of them) in during the event. We have a Panasonic 410 switcher. I know i have to downstream key it... But what I can't figure out - what software program I can use to create, or just keep track of the lower thirds > play them out of the computer into the switcher. I usually work with wirecast, so don't need a stand alone program. But now using "new" livestream procaster (ugh! wont work with wirecast).
Can anyone suggest easy, stand alone software for macbook laptop. Pro Presenter ? ANything easier? Again, just want to role in custom lower thirds to our switcher, DSK them..
any insight greatly appreciated.
Thxs
Chuck Pullen
Re: Creating/sending custom lower thirds during live stream event
on Apr 16, 2013 at 7:09:56 pm
I’ve always used Wirecast, and have migrated away from Livestream because of all of the limitations. CasparCG might work for you?
Chuck
Adam Cooper
on May 5, 2013 at 1:40:51 pm
Maybe ToolsOnAir or BugTV?
Joey Goodsell
on May 6, 2013 at 12:28:01 am
A simple solution is to use Keynote with a chromakey green background. Learned this from Alex Lindsay from Pixel Corp. You can build it in FCP/AE with animation then export it as QT and drop it in Keynote(if you can produce it in advance or simply create the template in Keynote and make text changes on the fly using different pages for each graphic/Lower third. Easy and it works with the keyer function of that switcher.
Kit Withnail
on May 16, 2013 at 12:24:15 pm
We create them in PS, then export to PowerPoint for text adding. Though PP is not pro quality, it does allow easy editing, which inevitably has to happen right before TX.
We take the HDMI out of the workstation and send it through an SDI converter, and use either chroma or luma keys with no problems.
This way your workstation's monitor can display PP's 'Presenter View' which enables you to simply click through your astons as required.
HTH.
