Affordable Switcher for Live Event
COW Forums : Live & Stage Events
andres garcia
on Jan 23, 2013 at 11:41:11 pm
Hi I need an affordable solution to mix in a live event the signal of one computer and 3 hd cameras, and project it in three videobeams.
I was thinkng in the Blackmagic Atem, but I read that it does not have scalers. Which would be the best option?
Thanks in advance
Andres Garcia
covisual.com
Seth Tours
Re: Affordable Switcher for Live Event
on Jan 24, 2013 at 11:57:35 am
You might want to look at the Panasonic AV-HS50N switcher.
4 SDI inputs and 1 DVI input.
http://www.panasonic.com/business/provideo/AW-HS50N.asp
Cheers,
Seth
Jim Brown
on Jan 26, 2013 at 2:02:11 am
A factor you may wish to consider is lag time (video delay) in your system. Anything beyond 6 frames becomes visible to your audience, Consider a projector is going to introduce anywhere from 2-5 frames and it does not give you much leeway in your switcher. You can optimize that by feeding the native resolution to the projector so that it is not rescaling.
For that reason we are very particular with cameras being the same and being genlocked. If you do that the ATEM works quite well.
If you must use different camera types and resolutions and rescale in the switcher then count on 2-5 frames of delay for the switcher.
Just $.02 worth
Jim Brown
M&M ProductionsUSA
