Problems with Glare from lighting on Monitors
COW Forums : Live & Stage Events
Ingo Weigold
on Jan 15, 2013 at 4:56:57 pm
Hi Guys,
We are having some issues with glare from our lighting on our studio. Can anyone make a suggestion on how to still have flat panel display with stage lighting and also cut down on glare?
An example of the problem is here:
**check out the glare on our monitor.
Thank you for any advice.
Mark Suszko
Re: Problems with Glare from lighting on Monitors
on Jan 16, 2013 at 10:49:17 pm
Tip the monitor slightly down. Or raise/move the light, or a little of all 3. Angle of incidence = angle of reflection.
You could also add a polarizing filter to your lens.
