Problem in rendering file size 2160x720
COW Forums : Live & Stage Events
esli Kaplan
on Dec 18, 2012 at 7:43:21 pm
Hi There,
I created an animation in After Effects CS5.5 for a presentation with some video footage and images at 2160x720 size, no audio. I'm trying to render a quicktime file in H264 codex but every time it renders at 2000x720.
I read most of the posts here and I see that there's an issue for rendering files over 2000px. I got a little confused with all the complicated posts that use multiple projectors and synced videos.
The Equipment that will be running my file is at 720p signal with 2 projectors and full screen size is 2160x760 quicktime file with H.264 codex.. It shouldn't be as complicated but I couldn't find a solution.. Any ideas?
Oh I also tried to render in iMovie quicktime export option, that renders the correct size but the quality looks super crappy..
Ken Geary
Re: Problem in rendering file size 2160x720
on Jan 30, 2013 at 12:59:55 am
I tried on my CS5.5, QT H264 output was fine @2160 X 720.
Check your scaling options in the encoding options window, you may have a preset checked off at 2000 pixels.
Michael Sisko
on Feb 22, 2013 at 1:11:44 pm
Are you still having this issue, how did you resolve it? What were you using for playback?
