HD video switcher Delay on My LED
COW Forums : Live & Stage Events
timothy chew
on Feb 25, 2012 at 4:56:04 am
Dear all expert
To change from SD to HD is our great dream
but in selecting Equipment .. it have been our nightmare
We are using sony EX3 and Datavideo 2000 and Black Magic Atem AME 1
our problem is we are doing live events like
speaking and dancing or singing Consert
When the Video running SDI back to out SEG
it is OK ..
then we use a Cat5e ( RJ45 )12 Video out distibutor to RJ45 to a COnvcerter to HDMI ) our sony LED TV
and we found out our LED video is delay
( if we dont use the HDTV , a PC LCD delay will be less
please give us some suggestion .. how to solve this problem
some expert said AME 1 Hardware Switcher problem
some said EX3 not high end to sync ,.
please give us your suggestion
and what is the best switcher to use now HD
and to record ..
Mike Jeffs
Re: HD video switcher Delay on My LED
on Feb 26, 2012 at 4:01:45 am
How much of a delay are you talking?
I have used ex3 on many occasions pertty sure that isn't your problem. I haven't used the blackmagic switcher but you say it doesn't have a dely when sending the signal one way, but that their is a delay when sending it through converters, my guess would be the converters or the LCD itself.
We run a large 15,000 seat performace space and there is a small delay with our video projectors but it is slight enough that its mostly un noticeable the only thing we have to do is delay the audio a few milliseconds to conpensate.
Mike Jeffs
Video Coordinator
BYU-Idaho
Jim Brown
on Feb 26, 2012 at 12:54:44 pm
I understand your frustration as we have been there, done that many times. A couple of things from our experiences. The EX1/3 will introduce no more that 1 frame of delay. The ATEM is about a line of delay if the sources are genlocked, which you cannot do with the EX series camera so that adds another frame for the frame synch in the switcher. You now have 2 frames of delay.
The display device is normally the biggest culprit depending on manufacturer, display rate and intermediate devices. If you are using baluns to route via cat5/6 cable their delay is minimal (one line or so). If the cable device is changing the resolution then add at least a frame. Most projectors add from 2 to 6 frames of delay. You can minimize that if you are sending in the native resolution of the display device. ie it is not doing a conversion itself. If your display is 720p and you are sending 1080i the resolution is being converted. If it is 1080p and you are sending other than 1920x1080 then a conversion is occurring. The ATEM is either 720p or 1080i so if it is a 1080p display a conversion is occurring.
The delays are cumulative so if you add a frame from the camera, a frame from the switcher, and two from the display then you are at 4 frames of delay. It takes a very focused professional to see anything less than 4 or 5 frames of delay. At 7 frames everyone can see it. Each frame of delay is 33ms. You can delay the audio up to about 66ms before you have unacceptable levels of echo. The speaker or performer will notice even 33ms but most of the time they are listening through monitors which you do not delay.
We evaluate equipment based on the following test. We use a very noisy relay to power a light bulb. (incandescent). We take a camcorder and record turning on and off the light and capture the sound of the switch. Take that to your editing software and you can see the light coming on in a frame of video and look for the spike in the audio for the switch noise. Note the difference. Use your EX3 and you will get a baseline of the difference in the camera. Then introduce the switcher to a fast reacting display. We use an old analog crt for this. The ATEM outputs a composite video signal and will give you a worst case result as it must convert the HD to SD. Video record looking at the display and take that footage and do the same thing. You now have the delay of the switcher plus this display device. Then video record the same thing with your led display and evaluate.
We normally find the projector or the flat screen is the culprit. Flat screens (both LCD and LED) are notoriously slow devices. Most of them are cost reduced and that conversion processing is the cheapest manufacturers can find and it does not matter with most applications. Projectors are the same way, but we have noticed that EIKI typically has the fastest processors. EIKI are Sanyo projectors with their electronics and we use EIKI, so take this info with a grain of salt if you wish. The key is to drive the display device with its native resolution where possible.
Hope this helps. It is a real issue which no manufacturer wants to discuss, much less disclose in their technical specs.
Jim Brown
M&M ProductionsUSA
timothy chew
on Feb 26, 2012 at 2:54:57 pm
one expert said
we need to change 1 thing
EX3 to higher end camera or Blackmagic to Panasonic
Do u guys think this work
Tim
Mike Jeffs
on Feb 26, 2012 at 5:39:37 pm
Again I ask how much of a delay are you getting, (ballpark?)
Like Jim said the EX3 and the Black Magic are probably only introducing a couple of frames MAX of delay. I think you are going to spend more money switching out your cameras and Switcher then you would finding out which piece in your infrastructure is add the most delay and finding a replacement for that. I could be wrong, but i'm of the philosophy of trouble shooting to the point you know what excatly is happing instead of blindly trying to throw money at a probelm when your not sure thats the culprate.
The more info you give us the more we can help you.
Mike Jeffs
Video Coordinator
BYU-Idaho
Jim Brown
on Feb 27, 2012 at 11:44:05 am
I would not exchange anything until I ran some tests as I described. I hate to make blanket statements but as a general rule I have found that Panasonic switchers add more delay than the Black Magic. Again, it depends on what the switcher is doing and is there resolution conversion, or interlace to progressive scan conversion, or ...
If I were betting with what I know I would point to at the LED display. They are notorious for delay and it can be several frames. Tell us what kind of display you have. A way to test is to connect your camera directly to the display (you may have to use an sdi to hdmi converter) and evaluate. If you notice latency it is in the display. (A converter is negligible in terms of latency. Typically they would be one line (1/525th of a frame). The EX3 is also very minimal (1 frame or less) coming out the SDI port.
You did not say whether you are connecting this via SDI (digital) or you are using the analog SD interfaces (composite or component). That could make a huge difference, especially in the display.
Jim Brown
M&M ProductionsUSA
timothy chew
on Feb 27, 2012 at 3:04:38 pm
thanks for your reply
THE Led We are using is sony 46nx720 and Heran 46z57
our crew make some test
( if connect to Normal LCD like PC monitor HDMI ) there is no delay ( may be less
BUt Even if we connect short cable from cam to LED ,... there is a delay
For the How much delay still need to test it out ( but u can see it with your naked eye there is a delay
( do this mean that LED is not suitable for live )or switcher also
Tim
Bruce Wheaton
on Mar 1, 2012 at 1:05:40 am
Be very careful on your tests. Your techs won't be able to tell the difference between 'no delay' and delay within 100 milliseconds or so. The brain just fixes A/V sync below that - it's a feature!
So your testing may actually be 3 frames delay versus 4 frames delay, and it won't look like 'a bit more delay', it will appear to suddenly be quite a bit off.
The main cause of latency for you is probably de-interlacing. Any time you go from an interlaced to progressive display, such as in a display device, or a DVE in a switcher, 1.5 frames is a usual minimum.
Have you tried 720p, if you're using 1080i right now?
For testing - make a video with a clear frame indicator. I have one knocking around somewhere with a white stripe that rolls past some frame markers - 5 or so, I recall. Feed that to a monitor. Shoot the monitor with a camera and feed the camera through your signal chain right to your display. If you can frame it to see the 'original' monitor and the post-processing monitor or display, you end up with a video you can pause and examine.
Bruce
Regards,
Bruce Wheaton
http://www.synchromeshDDR.com
timothy chew
on Mar 2, 2012 at 10:11:10 am
I just want the delay to be unseen will do
By the way I saw people using
( using HDMI ) or SDI .. I think is HDMI
And there is a projector ( live )
Why dont there feel the delay ..
And for Latency problem
We also setup a Vidblaster Demo with osprey 460e
Any one try it before
I also suffer latency On SD signal
Any sure ...
( I am doing live feed also )
Tim
