Panasonic HS400 down conversion issue
COW Forums : Live & Stage Events
Calin Way
on Oct 26, 2010 at 7:57:19 am
I am working with an Hs400 with two HD cameras running full 1080i. The issue I have hit is that they want a recording on a DVD recorder and an encoding computer for the web. I was trying to use the down conversion option on the switcher to feed this signal but it doesn't seem to work, I've been working on this for a few hours, i would love it if someone could tell mr where I am going wrong.
Chuck Pullen
Re: Panasonic HS400 down conversion issue
on Oct 28, 2010 at 3:57:00 pm
What card is installed to down convert? Are you sure you have one? You may have to get a down conversion box from AJA or Blackmagic to make this work...That's how I do it.
Chuck
Alan Teo
on Nov 19, 2010 at 6:30:06 pm
chuck,
which device did u use? I used a blackmagic Sdi-to-analog and it gave me one frame delay after converting.
