The Warrior’s Way
COW Forums : Live & Stage Events
Will Key
The Warrior’s Way
on Oct 11, 2010 at 7:37:48 pm
Guys I know this isnt the right forum Put where should I put a question about a projector? If any one does know the answer to to this please help !!! :)
I have a projector up in the control box so we have to run it VGA to LEMO then to the patch bay, out the patch bay LEMO to vga into the projector. When we do this it looks horrific. We put a booster box there it helps a bit but not massively it makes it look like somthing that looks like someone has smudged... is there anyway to do this other than a ridiculously long VGA cable?
Joel Hufford
Re: The Warrior’s Way
on Oct 12, 2010 at 5:04:12 pm
Have you looked at Baluns as an option? These devices allow you to send VGA signal over Cat5 cable. The distance you can send the signal depends on the specific device.
Here is a link to two options offered by Gefen. I'm sure others on the forum could offer up some other brands they've had success with.
Corporate and Special Event Staging Services
© 2018 All Rights Reserved
