play a 4,800 x 600 video across 2 graphics cards outputs
COW Forums : Live & Stage Events
Maxim Moisseev
on Jul 21, 2010 at 5:22:16 pm
I've recently encountered a problem I can't resolve now.
How to play a 4,800 x 600 video file across 2 graphics cards outputs with a triplehead to go on each on a PC, using openGL output?
Is there a player capable of this?
http://www.transscreen.ru - clear projection films and touchscreen.
Thomas Leong
Re: play a 4,800 x 600 video across 2 graphics cards outputs
on Jul 21, 2010 at 6:45:00 pm
That's ONE video file assigned to 2 gfx cards each with a TripleHead2Go.
I only know of one software-cum-player that allows you to assign one file to two gfx cards (max 4 outputs, 2 from each card), but not sure if it works with a TripleHead2Go. It is AvStumpfl's Wings Platinum 4 Multi-display version with 4 outputs, read "2 dual-display licences (USB-keys)". The software will auto sense the 2 licences and combine to give you 4 outputs from one PC. BUT...price might be a factor for you.
One possible alternative is freeware Multiscreener from zachpoff.com. It can run Server and Client player on one PC, but seems to work only with Quicktime-playable video files, eg. .mov, .qt, .mp4, etc. There is an option in lower right corner for 'Device Options' - not sure what it is as my laptop does not have 2 gfx cards, but at a guess, hope it allows one to select the gfx card or output device for the Server and the Client separately.
Thomas Leong
Thomas Leong
on Jul 21, 2010 at 6:48:16 pm
Forgot to add -
With Multiscreener, you will need to pre-split your ONE video file into 2 files (with After Effects).
Walter Soyka
on Jul 22, 2010 at 7:31:24 pm
[Maxim Moisseev] "I've recently encountered a problem I can't resolve now. How to play a 4,800 x 600 video file across 2 graphics cards outputs with a triplehead to go on each on a PC, using openGL output? Is there a player capable of this?"
That seems like it'd be very taxing on a single computer -- it's the sort of thing I'd usually split across a network. I'd be curious to hear if Thomas's suggestions work for your application.
The only other thing that I'd note is that 4096 (4K) is a "magic number" in video: OpenGL and DX9 hardware is typically limited to 4K x 4K (though some newer OpenGL and DX10 cards double that in each dimension to 8K x 8K). Some codecs may not support raster sizes beyond 4K, so compression and playback could be a challenge, too.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Maxim Moisseev
on Jul 22, 2010 at 7:43:14 pm
There is no magic in this number, Walter.
This is maximum size of the Direct3D texture, so if player outputs using OpenGl it's a limitation, as it treats any raster as a texture.
There's a simple player for OSX - MSAQTPlayer, that can override this limit. But seems no one for PC.
Walter Soyka
on Jul 22, 2010 at 7:48:18 pm
I've used the term "magic" colloquially, of course. Again, note that the texture size has been increased to 8192x8192 in DX10.
Walter Soyka
Walter Soyka
on Jul 22, 2010 at 8:00:03 pm
[Maxim Moisseev] "There's a simple player for OSX - MSAQTPlayer, that can override this limit."
I've never used this tool before -- thanks for brining it up. Do you have any experience with it?
Walter Soyka
