Quartz Composer - Motion Plugin
COW Forums : Live & Stage Events
Patric Logan
on May 26, 2010 at 9:28:37 am
I want to create simple plugin, which creates flashes on the screan and
read light coordinates. I want to work this plugin in Aplle Motion. Is
there any way to do that plugin in quartz composer, which works like
- user in Motion can select how many flashes he wants to put on the
- user can read light coordinates when he pushes the button,
- all plugin have to work in separate window [not only in inspector in Motion].
Can u write me is quartz compose has that components to do that kind of
plugin? And is the fxfaxtory can convert it to Motion?
Or maybe i should do it different way?
Thanks for your answer!
© 2018 All Rights Reserved
