Advice on bkg light fixtures for a small studio
COW Forums : Live & Stage Events
William Meese
on Nov 29, 2009 at 8:46:45 pm
I'm building a small (10' x 10') webcast studio for a client. Planning to use a simple muslin backdrop. I'm looking for low/no budget solutions for lighting the backdrop--as in what fluorescent lights could I get at Home Depot? Any suggestions on brands to look for, or things I should avoid?
Vince Becquiot
Re: Advice on bkg light fixtures for a small studio
on Dec 1, 2009 at 5:08:20 am
A muslin backdrop looks best when you can't really see what it is.
You would be better off looking for a 1 or 2 300w Fresnels on eBay.
Fluorescent lighting is way too flat.
You could try setting up a low powered work light and create some areas of shadows with it as well, but why not start to invest on lights you can use for other area of production?
Vince Becquiot
Kaptis Studios
San Francisco - Bay Area
William Meese
on Dec 1, 2009 at 5:03:24 pm
Thanks, Vince.
This is a small webcast studio in one room (10' x 10') of the client's offices. No other production is planned, and the budget is tight. I'm considering fluorescents to keep the power needs and heat down.
Good tip on the muslin--I just looked at a similar setup that used plain, dark drapes as bkg--gave some texture yet didn't compete with foreground.
Vince Becquiot
on Dec 1, 2009 at 5:11:57 pm
In that case look at small spot lights at Home Depot. Add a couple of those metal clamps and you should be set.
William Meese
on Dec 2, 2009 at 7:34:19 pm
You're right; that'll do the job and that'll fit the budget. Thanks.
