Continuous operation camera with slow shutter speed needed
COW Forums : Live & Stage Events
Pat Wickline
on Feb 23, 2009 at 11:38:05 pm
I need a camera that operates continuiously and applys a slow shutter speed effect. I use this to re-project the image of moving objects real time. I don't need to roll tape.
How can I achieve this? I do it currently with a camcorder, but I have to actually be rolling tape because if I have the tape on pause the camcorder turns itself off after 10 minutes.
Pat
Thomas Leong
Re: Continuous operation camera with slow shutter speed needed
on Feb 24, 2009 at 2:03:55 am
Try this with your cam (assuming it has the slow shutter speed you require). Take the tape out and operate without, and you will likely find that it won't switch off when in pause mode. Apparently, the retail shops do this when demo'ing a cam outside their shops.
Thomas Leong
