BCC 3 Way Color Grade is missing from Continuum Complete 10 OFX for Vegas?
COW Forums : Boris FX
James Ollick
on Jun 2, 2017 at 2:04:50 pm
Does anyone have Continuum Complete 10 OFX for Vegas? If so, can you check and see if you have 3 Way Color Grade under Color and Tone? It is listed on their website and does not say anything about any of the FX being compatible with only select hosts.
James Ollick
James Ollick
Re: BCC 3 Way Color Grade is missing from Continuum Complete 10 OFX for Vegas?
on Jun 3, 2017 at 11:44:59 am
Boris got back to me with this statement "Unfortunately, the BCC 3 Way Color Grade filter will only load inside Adobe After Effects and Premiere Pro, so this is why it's not appearing inside your Vegas. " Hopefully it will be available for Vegas in the release of BCC 11.
James Ollick
James Ollick
on Nov 29, 2017 at 10:13:02 pm
Well, so far, BCC 3 Way Color Grade is also missing from Continuum Complete 11 OFX for Vegas :-(
James Ollick
peter mcauley
on Dec 5, 2017 at 6:04:25 pm
Hi James,
The problem is that the OFX (and AVX) API currently does not allow us to generate the UI features that are necessary for this filter to be usable in Vegas (or Avid) so until that changes we can't make the filter work within these hosts. It's unclear to me when this is going to change but if if the API opens up then we'll definitely make this filter available within Vegas and Avid.
Peter.
James Ollick
on Dec 6, 2017 at 1:43:04 pm
Thank you Peter for the response.
James Ollick
